Michigan Wheel 3-Blade Prop, Pressed Rubber Hub / Aluminum, 9 dia x 10.5, RH
Michigan Wheel propellers are designed for trouble-free service and easy repairability. By using only the finest grade alloys, Michigan Wheel aluminum propellers are stronger than most OEM propellers. The rubber hub bonded inside every Michigan Wheel propeller helps protect expensive shafts, motors, and gear boxes from potential damage caused by underwater impact. Vendor Part Number: 032050Applications: Force/Chrysler/U.S. Marine: 9.9-15 HP, Thru Hub Exhaust, 8 Tooth Spline, 9.9 HP, 1996-1998; 15 HP, 1996-1998Mercury/Mariner/Sea Ray: 6-15 HP, 2-1/2" Gearcase, Thru Hub Exhaust, 8 Tooth Spline, 6 HP 2-Stroke (Includes Merc 6) , 1986-2002; 8 HP 2-Stroke (Includes Merc 8) , 1986-2005; 8 HP 4-Stroke (Not Bigfoot) , 1995-2004; 9.9 HP 2-Stroke (Includes Merc 9.9) , 1986-2005; 9.9 HP 4-Stroke (Not Bigfoot) , 1995-2004; 10 HP, 1995 Newer; 10 HP (Sea Pro/Marathon) , 1995-2001; 15 HP (S.
